Turbo Boost Pressure Code---Help
Old Sep 6, 2012 | 11:06 AM
Stroker6-0's Avatar
Stroker6-0
A friends of mine has a 04 6.0L with 70,000 miles and the car will not turn over. It sounds fine when cranking it just wont fire/turn over. I plugged in my SCT tuner and got the code P2262 which is the Turbo boost pressure not detected. We drained all the fuel lines and it still is doing the same thing when trying to start. I read in some other posts that there is a filter on the fuel pump but im not sure that the problem is fuel related anymore. The owner said that he is missing a bolt on the turbo so I am wondering if it is sucking air in and if this is causing the problem. Any ideas or help would be great. Thanks
Old Sep 6, 2012 | 11:21 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Try this check list found in the tech folder.
https://www.ford-trucks.com/forums/8...condition.html
If every thing is connected, remove cap and filter on top of motor. Have someone turn the key on and see if it fills quickly.
Is this an early build or late build 04? (ICP is on the passenger side valve cover on a late built 04)
Any gauges available to look at? If not, you might suggest to your friend he needs some.
Old Sep 6, 2012 | 11:24 AM
amdriven2liv
Oh, there are a lot of trucks running around with a bolt missing from the turbo mount.
Check all connections into and out of turbo. What was he doing when he got the code?
Old Sep 6, 2012 | 11:57 AM
Stroker6-0's Avatar
Stroker6-0
Hey thanks amdriven2liv, thats a good link. Ill check it out and see if it helps. Appreciate your help!!!
Old Sep 6, 2012 | 12:06 PM
Stroker6-0's Avatar
Stroker6-0
he said that he was driving and that the check engine light would come on and go off periodically and that it was running fine. He parked his truck and went out the next morning and it wouldn't start. I plugged in my SCT tuner and read the DTC's and it pulled the code p2262.
olyellow
Nov 6, 2018 08:16 PM
white04kr
May 20, 2012 10:13 AM
Mike Harnsberger
Nov 28, 2010 08:03 AM
cak301
Apr 27, 2010 06:34 PM
Griesel
Feb 9, 2006 09:42 AM
