door tags
Old Sep 5, 2012 | 06:28 PM
soldier233rd's Avatar
soldier233rd
door tags
Need a little help if possible. Stopped at the local JY today and found three dents and one bump. What I'm looking for is a little help reading door tags. I'm trying to narrow down my search for rear end gears. The first tag is from a 76 F150 trans stamp is G axle is 14J.
The other one is from an F100 didn't get the year but trans is coded C and axle is 09.
Old Sep 5, 2012 | 06:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
14J: 14 = 9" 3.00-1 without Limited Slip / J = Power Steering.
09 = 9" 3.70 -1 without Limited Slip.
If the AXLE code begins with a letter: Limited Slip / If with a number: No Limited Slip.
G is the A/T code / 1961/78: FoMoCo used the same G code for all A/T's. One had to know which trans was available with what engine.
C = 1966/79 Ford type 3.03 3 speed manual all syncro trans.
Some 1976/79 F100/150's have Dana 44 rear axles. If there's an inspection cover = PASS!
Old Sep 5, 2012 | 07:35 PM
soldier233rd
Thanks for the info. Looks like I'm going back for a closer look tommorw, and pull those 3.70 out and see if they are still in there. As I'm running 2.75's right now. My axle stamp is 13.
Old Sep 6, 2012 | 10:32 AM
NumberDummy
13 = 9" 2.75-1 w/o Limited Slip.
squirrelmaster
1978 - 1996 Big Bronco
May 15, 2016 03:48 PM
i1dery
Feb 2, 2007 02:04 PM
jav409
Dec 13, 2004 06:14 AM
Rulebreaker
Bronco II
Dec 5, 2004 11:30 PM
fordson
Oct 24, 2000 11:13 PM
