95 Bronco 351 into 77 SuperCab?
Old 09-05-2012, 09:22 AM
fitzwell's Avatar
fitzwell
fitzwell is offline
one question i haven't found the answer to.. yet. The 95 351w has a rear sump oil pan. Has anyone here done a similar swap? Trying to see if i need to switch to a front sump, or will the Bronco unit clear?
TIA,
mike
Old 09-05-2012, 08:45 PM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
oil pan?
just thinking on subject. should be a mid sump for 4wd. your main concern is clearing differential in 77 supercab. is supercab 4wd? if 4wd chasis should be a open setup compared to crossmember below engine. things to think about. not totally sure on this subject but things i look for.
Old 09-06-2012, 08:40 AM
fitzwell's Avatar
fitzwell
fitzwell is offline
Sorry... 2wd.
Old 09-06-2012, 07:35 PM
loudfords's Avatar
loudfords
loudfords is offline
It fits with no issues, my 79 is running an 88 351w with rear sump oilpan for the last 9 years.
Old 09-07-2012, 08:32 AM
fitzwell's Avatar
fitzwell
fitzwell is offline
thanks. What did you do for exhaust, Stock manifolds, shortys, or long tube headers?
Old 09-20-2012, 07:32 PM
loudfords's Avatar
loudfords
I used Mustang shortys. If I were to do it again, Summit brand longtubes fit from what I've read here.
hasteranger
04-29-2016 03:28 PM
fordman7705
12-21-2014 07:28 PM
FarmerFrank
02-20-2010 09:23 AM
79 posi
Engine Swaps
11-30-2004 10:42 AM
92EBBronco
1978 - 1996 Big Bronco
10-16-2004 03:22 AM
Quick Reply: 95 Bronco 351 into 77 SuperCab?
