Glow plug question
Old Sep 4, 2012 | 04:01 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
Glow plug question
hey guys, I thought i remembered there being a write up about how to r&r glow plugs, but i havent been able to find it... anyone know where i can find one? I'm pullin my gp's and want to make sure i dont miss any important steps...
Right now i've just got the valve cover off, and i'm stopped there so i don't mess anything up lol
Thanks in advance!
Old Sep 4, 2012 | 04:12 PM
427 fordman's Avatar
427 fordman
Not much you need to worry about with the gp's Daniel. Carefully loosen the old ones. If they are motorcrafts(hopefully they are), they should come out pretty easy. I used a short piece of rubber hose to start the new ones back in, just like I do a sparkplug.
Old Sep 4, 2012 | 04:15 PM
f350rebel7788
Do I need to remove the injectors, or will I Be able to get around them?
Old Sep 4, 2012 | 04:19 PM
427 fordman
You can get around them.
Old Sep 4, 2012 | 04:22 PM
fordpride's Avatar
fordpride
You will need a thin wall deep 10mm. socket
Old Sep 4, 2012 | 04:46 PM
richdawg's Avatar
richdawg
Here is the link for about everything and more about GP's
https://www.ford-trucks.com/forums/4...ke-thread.html
Old Sep 4, 2012 | 07:18 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Rich, thats and OLD thread but very good one. I miss that guy: 1997F-350, his last activity here was in 2010.
Old Sep 5, 2012 | 01:08 PM
f350rebel7788
Alrighty, just finished up. You were right, Darin, nothin to em. They all pulled right out, no problems. I'm pretty sure they were the originals too. They were nasty! She runs much better now! Still a little white smoke, but nowhere near as bad... You thing that might be a PCM issue?
Old Sep 5, 2012 | 01:26 PM
stainlessstroker95's Avatar
stainlessstroker95
Did you check the valve cover gaskets and pig tail for burnt pins?
Old Oct 2, 2012 | 03:37 PM
f350rebel7788
negative... guess i should try that, huh? lol
Old Oct 2, 2012 | 05:02 PM
Red97350's Avatar
Red97350
Not to hijack, but I'm about to do this on my truck, and I was curious if anyone used an anti seize or anything like that on the glow plugs before they install them.
Red
Old Oct 2, 2012 | 05:33 PM
Talyn's Avatar
Talyn
Red
I do.
10char
Old Oct 2, 2012 | 05:34 PM
Talyn's Avatar
Talyn
Been so long I forgot about him. I believe he sold his truck.
He was always nice to have around.
I remember his Icon.
Speaking of MIA, where is Sam?
Old Oct 2, 2012 | 06:23 PM
Usaman's Avatar
Usaman
Glow plugs
Always a good practice to ohm them out at the harnesses before and after you reinstall the VC's. Sometimes the Glowplug connectors need to be pinched to get a good grip and take notice where the glow plug lead will rest. ensure its not tucked under the gasket and out of the way of the rocker arms, vibration, rubbing and all.
the brake hose is good but I;ve had to use clear 1/4" hose with a slight maybe 3/16 slit cut longitudnially at the tip to slip over the probe real tight for getting in and getting out. Sometimes the excess oil makes the hose slip and not even brakecleaner sprayed on the hose can get it to grip just right sometimes. BTW the Glow plug is a metric 1-10 extrafine thread if you run into a crossthread problem on # 7 or 8. had a slight problem once but an old plug worked out great in rethreading it.
Used a copper type antiseize cmpnd.
madMatador78
Sep 25, 2013 04:44 PM
Benny76
Dec 22, 2012 03:40 PM
4EXTRDR
Dec 16, 2010 07:11 PM
1999SuperDutyStroke
26
Apr 28, 2010 07:04 PM
97biostroke
Feb 8, 2009 01:51 PM
