ranger electrical issues stumpted
Old Sep 4, 2012 | 03:07 AM
2002exPSD's Avatar
2002exPSD
on my 97 ranger the speedo and odometer dont work. already replaced the vss and they still dont work. worked when i bought the truck 2 months ago. and the wipers worked when i got the truck now they dont. checked all fuses, checked for power at the motor and getting nothing. and the fuel gauge quit working a week ago.
Old Sep 4, 2012 | 06:59 AM
pawpaw's Avatar
pawpaw
Did all of these problems begin after some event????
If not, then you may have more than one problem.
Do you have a CEL lit, if so, have the computer scanned for trouble codes & post All code Numbers found, as they can provide good trouble shooting clues. Most autoparts stores will scan for codes at no cost, if the CEL is lit.
Old Sep 4, 2012 | 10:36 AM
2002exPSD's Avatar
2002exPSD
No cel light. Have my own scanner and nothing comes up. All I did was let the truck sit outside for hurricane isaac for 3 days.
Old Sep 4, 2012 | 03:49 PM
wtroger's Avatar
wtroger
Check all your ground connections. Battery, block and chassis grounds interior and exterior that kinda of moisture can cause a lot of problems. Might not hurt to to disconnect and dry out the ecm connector.
Old Sep 4, 2012 | 05:13 PM
2002exPSD's Avatar
2002exPSD
Only ground I found disconnected was the hood ground.
87 XLT's Avatar
87 XLT
The cruise control probably gets it's speed input from the same VSS. Is the CC working?
Old Sep 4, 2012 | 06:43 PM
2002exPSD's Avatar
2002exPSD
CC never worked. Buttons disenigrated.
ff4everga
Jun 5, 2015 11:10 PM
JimmySticks523
Feb 20, 2005 08:06 PM
mramelbass
Electrical Systems/Wiring
Aug 30, 2004 11:39 AM
boartracksca
Aug 1, 2003 07:50 PM
67'EconoHotrod
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 1, 2003 11:02 PM
