1978 - 1996 Big Bronco
Electronic Door Locks
Old Sep 3, 2012 | 08:30 PM
Fordman96's Avatar
Fordman96
This problem has persisted for a week but I haven't had time to check into it. I was headed home one night and while driving I hit the door locks (like always) to lock the doors. They locked but when I got home, about 15 minutes later. I went to lock the truck up for the night and... nothing. "lock" and "unlock" don't work on either door. The next day I went out and checked all the fuses (none are blown) and everything else in the trucks works sound. I feel it's something in the wiring between the 2 doors but I'm not entirely sure. Any and all suggestions are welcome because this problem needs to be fixed so I can sell the truck
Old Sep 4, 2012 | 10:38 AM
greystreak92's Avatar
greystreak92
Check the wiring to the passenger door switch first. Yes, believe it or not, the harness originates on the passenger side than travels across to the driver's side. Make certain the wiring to ground "F" (behind the left lower cowl panel) is secure and no corrosion exists. The symptoms honestly sound like a weak or loose connection and that's where I'd start.
Old Jan 11, 2013 | 06:33 AM
Fordman96's Avatar
Fordman96
I finally got around to this issue about a month ago but i didn't update this post. I checked the grounds and all the wiring connections when i had the chance to (but i didn't get to run a continuity test.) and all the grounds are uncorroded and secure. After looking over a diagram of the wiring i'm still stumped. What are the chances that the motors just gave out?
Old Jan 11, 2013 | 09:18 AM
greystreak92
They say anything is possible. You can always jump a positive and negative feed from the battery directly to the lock solenoids. Yes, you need both because of the way the switching is done. You have to touch both positive and negative to the solenoid AT the solenoid in the door to get them to do anything. (When the lock switch is not pressed there is neither positive nor negative fed to the solenoids.) if the solenoid doe not respond, swap the positive an negative test jumpers. If it does not respond after reversing polarity, then the solenoid is the culprit.
ecks405
1997 - 2003 F150
May 16, 2019 09:31 AM
V8Ranger302
32
Feb 5, 2013 09:52 PM
6_Myles
Oct 26, 2010 10:35 AM
lauraj
Jul 18, 2010 05:19 PM
m thatcher
Bronco II
May 25, 2005 01:10 AM
