Well, here is what I would do if it is mine. I'd keep the 351M or make it into a 400 & put a 4BBL intake & carb then do dual exhaust (fortunately one the previous owners did that to Rustoleum already [Less money to drop into her ]) . But, overall its your truck do what you want. But, we will be happy to give opinions !
Well it has dual exhaust, but I am going to replace all the tubing and mufflers for the sake of my addiction to wanting everything to be perfect. I already bought Flowtech long tubes, just havent installed yet. I will probably either turn the 351 into a 400 (crank and pistons), put a 4bbl carb and intake, new camshaft or buy this 460 and build it perfectly for the next couple of years and swap it at a later date. If I do that, Ill just put the headers on it to give me a decent sounding truck. Who the hell knows. I am so figgin torn. idk wtf to do haha
Off topic but the performance build up link above said you must change the harmonic balancer if upgrading to 400 crank(use 400 balancer). I bought a 400 long block but I used the 351 balancer. Should I switch to 400 balancer ? First I've ever heard of this but I'm by No means an engine builder. Any comments? sorry 4 the high jack of thread
A Comp Cams 268, Edelbrock Performer and a Carter 625 with headers can really wake up a 351M....AND you'll have dudes asking you if its a 390!! LOL. That's my experience with it. Oh....and you should convert your rocker arm bolts to screw in studs and Crane has a kit for that. Easy to do, all the instructions are provided.
"Off topic but the performance build up link above said you must change the harmonic balancer if upgrading to 400 crank(use 400 balancer). I bought a 400 long block but I used the 351 balancer. Should I switch to 400 balancer ? First I've ever heard of this but I'm by No means an engine builder. Any comments? sorry 4 the high jack of thread"
Short answer - yes, they are different
