carberator problem
Old Sep 3, 2012 | 01:59 PM
granite bed f1's Avatar
granite bed f1
carberator problem
Stock 240 I have no vacum at carb. has been idel 1982 on have re built frame up is it the carb? and what can I replace it with. No new stock that I have been able to find, THANKS. you guys are great, wish I knew more about this computer thing. I have rebuilt the carb.
Old Sep 6, 2012 | 08:33 AM
Freightrain's Avatar
Freightrain
It runs? Not sure what you mean by no vacuum? At the ports on the bottom of the carb?
Could be wrong base gasket plugging hole off?
Old Sep 8, 2012 | 11:43 PM
orich's Avatar
orich
No vacuum at carb hmm most carbs at low idle will not have any like rpm is 500-550 until you raise engine rpm. But the intake manifold will have the 17-20 inches of vacuum. The carb port goes to dizzy vac. advance. So it all maybe ok and your worried for no reason ...orich
nlareau
Sep 18, 2011 07:19 PM
Greenmachine360
Sep 11, 2008 08:25 AM
rmoore7167
May 28, 2007 04:12 PM
klondrie
401, 477, & 534 SD Engines
Apr 12, 2005 05:27 AM
bondo man
Sep 18, 2002 10:24 AM
