I have a 72 f100 with a 360 stock other than slightly larger valves that were put in the heads before I got it during a rebuild. I am putting on headers and a Edelbrock Performer RPM intake manifold, but I was wondering what would be the best carb to go with this?
My opinion............600 vacuum Holley. I'm a Holley guy, so I like them. Others hate them with a passion and will tell you to get a E-bok(carter type) carb.
Ya, plain vacuum version, I don't think the double pumper version is a good street carb. You could bolt a 750 on it, but unless you really plan on twisting it high rpm, I don't think it will need that kind of fuel.
I agree with Freighttrain. I just took off a practically new Edelbrock and replaced it with a 4160 I rebuilt on my 390. Plenty of carb. Runs way better now. A 750 would probably work, but I doubt would help any.
Thanks for the input. I am trying to get the truck ready for winter as it will be my primary mode of transportation because my other car is a firebird with street slicks. Do the electric chokes on the 4160's work pretty well cold?
its the power valve that goes bad from a backfire and the new holleys do not have that problem i like holleys and edelbrock i have never owned a edelbrock but would like to try one out in place of my old 750 holley just for kicks
In 20 yrs of having Holleys............I've NEVER, repeat NEVER, EVER had a power valve blow out. I guess you basically have to really screw up the tune up and continue to try to drive it to blow them out? I don't know? I run TWO of them on THREE of my vehicles with no issues.
I had two 600's on my blower motor and still never had them blow the power valves out. I've replaced them with 660's center squirters which don't have PV's, as it needed more fuel.
