Sending unit from LMC bad?
Old Sep 2, 2012 | 10:19 PM
78bigunns's Avatar
78bigunns
I am using one tank on my 75' right now, the in cab.
The sending unit was deemed non functional, after I cleaned the ground, it still didn't work so then took the positive and grounded it, which it was now pegging the gauge to be full.
Ordered a new sending unit from LMC, installed it.
I fill the tank, gauge reads full. I drive around, it goes down to empty.
However every time I fill up, I'm only putting in a half tank.
Is this a wiring issue, or is the sending unit they sent me a dud?
Can it be adjusted?
Any thoughts or input welcome.
Thanks
Old Sep 3, 2012 | 12:02 AM
mikeo0o0o0's Avatar
mikeo0o0o0
They can be adjusted to some degree by bending the float arm.
In your case it sounds like the gauge is reading empty, or close to it, when it is actually still half full, you need to bend the arm down some.
Old Sep 3, 2012 | 12:38 PM
kobaltblue's Avatar
kobaltblue
This should help ya out.
Fuel Tank Sending Unit Tech - FORDification.com
82fordowner
Sep 2, 2013 07:37 PM
moparmusclecars
Oct 25, 2011 09:04 PM
blk dog
Oct 31, 2010 01:52 PM
Rcodenewf
Nov 4, 2009 01:28 PM
billb7984
1947 and Older Ford Trucks
Jan 17, 2008 06:40 AM
