rod bearing?
Old Sep 3, 2012 | 12:23 PM
Schickel's Avatar
Schickel
rod bearing?
Alright so ive done some asking around and i think the loud knocking coming from my engine is a rod bearing. So my question is what kind of trouble am i getting myself into by fixing this on my own? And also is this even the problem like i said its a loud knocking that has gotten worse over the last few short trips ive taken
Old Sep 3, 2012 | 12:27 PM
meatloaf_CC's Avatar
meatloaf_CC
Does the knocking get louder and worse when under load? If its a rod bearing you might as well get a new engine, or do an entire rebuilt. You've gotta pull the whole bottom end out to get to it. Chances are if that went, the engine is worn out and ready for some love anyway.
Old Sep 3, 2012 | 12:28 PM
smokenchoken's Avatar
smokenchoken
need info
what motor and what model truck? give us an idea what your playing with and possibly your skill level
Old Sep 3, 2012 | 12:41 PM
Schickel's Avatar
Schickel
Its a 77 f 250 custome with the 400m. My skill level is a work in progress but my friend is a mechanic for a ford dealer and hes gonna give me a hand
Old Sep 3, 2012 | 12:42 PM
Schickel's Avatar
Schickel
And yes it gets louder as i rev it or am going up a hill
Old Sep 3, 2012 | 01:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
More than likely a rod. If it's knocking then the rod bearing has probably "spun" inside the rod.
Easiest is to just plan on a complete rebuild. It can be "repaired" but the work involved is almost the same as a complete go through.
Minimum is crank turned or replaced, at least one connecting rod and main/rod bearings replaced. Be sure to replace the oil pump too.
F-250 restorer
Feb 9, 2018 06:28 PM
ihateminimumwage
13
Sep 4, 2006 09:54 PM
chapper
Feb 23, 2005 11:34 PM
Jerky38
Feb 15, 2004 01:11 PM
kdhartley
Oct 27, 2003 07:19 PM
