05 Explorer trans issues
Old Sep 2, 2012 | 04:16 PM
jlp0573's Avatar
jlp0573
When I put it reverse it goes in gear but when you add throttle it makes a terrible noise when its backing up. All foward gears are ok. Help.
Old Sep 2, 2012 | 05:43 PM
aquanaut20's Avatar
aquanaut20
Sounds like you have a defective sprag, only remedy is a tear down.. Philip
Old Sep 3, 2012 | 11:08 AM
jlp0573's Avatar
jlp0573
It's not that bad. Is it ok to drive it or will it cause more damage.
Old Sep 3, 2012 | 11:51 AM
aquanaut20's Avatar
aquanaut20
Noise has never been an indicator of things doing well.. However if you refrain from reversing you may survive longer... Philip
Old Sep 3, 2012 | 05:50 PM
jlp0573's Avatar
jlp0573
Can you suggest a good trans shop. Should I go with a chain like aamco or look for a local shop. What is the going price for a rebuild. Thanks Jeff
Old Sep 3, 2012 | 06:19 PM
aquanaut20's Avatar
aquanaut20
jeff,
That is where you shall have to do some local research. Ask around until you have several positive replies (from customers)....
There are many shysters in the trade and those that do minimalist work... Philip
Old Sep 4, 2012 | 08:57 AM
KhanTyranitar's Avatar
KhanTyranitar
Look for a shop that has a good BBB rating, and that has an owner on site, and that actually recommends rebuilds over swaps.
As far as cost, a good shop will do what is called an RDI (Remove, Disassemble, and Inspect), since an accurate quote can never be given when hard part damage is present without partially disassembling the unit.
A shop that is a member of ATRA is a good choice, since most ATRA shops have good reputations, and ATRA has a nationwide warranty larger than any chain.
RaceDog
Dec 14, 2010 09:10 PM
bwright
Dec 19, 2005 08:27 PM
Kraut
18
Nov 19, 2005 05:04 PM
