A short?
Old May 14, 2003 | 08:35 PM
Sluggercat2's Avatar
Sluggercat2
Question A short?
I own a 87 F150 5.0L and every so often my headlights, radio. door locks cigar lighter and maybe some other things just cut out. Sometimes after I hit a bump other times its just that way when I start her. Truck runs fine the whole time. What is it these have in commom besides the battery? Any ideas, I'm stumped.
Thanks
Old May 14, 2003 | 08:37 PM
Franklin2's Avatar
Franklin2
A short?
A connection on the starter relay(large terminal on the battery side) feeds all these circuits. Also there may be a big plug on the firewall that may have worked loose, or gotten wet and corroded.
Old May 15, 2003 | 06:48 PM
steve83's Avatar
steve83
A short?
It's probably a bad ignition switch. Does it have a positive return-to-RUN feel, or is it slow/loose? They're cheap & easy to change. Next time they go out, try wiggling the key back & forth to see if they kick on.
Old May 15, 2003 | 10:36 PM
Franklin2's Avatar
Franklin2
A short?
I didn't think the headlights went through the ignition switch.
Old May 16, 2003 | 12:08 PM
steve83's Avatar
steve83
A short?
You're right - they don't.
Old May 16, 2003 | 01:47 PM
thelonerangerxlt's Avatar
thelonerangerxlt
A short?
Mr Sluggercat, there's a small ground wire coming off the negative battery cable, that connects to the radiator surround. This is a ground for the headlights, but it may affect other circuits too. Make sure the connection is clean and tight.
dwil
Arizona Chapter
Apr 7, 2014 09:18 AM
ftrk66
Dec 11, 2012 11:53 AM
Gwilkrrs
118
Aug 5, 2007 10:04 PM
hans88
Apr 26, 2006 10:17 PM
caseys
Aftermarket Products
Oct 17, 2005 12:50 PM
