Advantages of Improved Air Intake?
The problem with the stock airbox is that it is not unusual for it to warp slightly along the sealing areas of the filter box allowing unfiltered air to enter. Check your intake and turbo fins for any 'dusting' or 'sandblasting'. Feel the passage just before the turbo for any fine abrasives. If you have any of this, you have problems with the stock box and you're slowly ruining your motor. So the greatest advantage to a good aftermarket set up is clean air. Some claim they see slight MPG increases and/or lower EGT's, but that also depends on what other mods have been done. I used to have the 6637 and it filtered very well, (as verified by Blackstone OA), but just recently replaced it with the S&B set up. For me it was simply wanting a more enclosed style filter set up.
5. Slow
43
10-07-2010 12:10 PM
deanzawistowski
01-28-2008 10:23 AM
