Trouble starting when hot
Old Sep 1, 2012 | 12:18 PM
spudgunman's Avatar
spudgunman
Here is the problem
If I run till engine hot, park.. Wait about 10min try and start ..
The starter will have a hard time starting the engine, eventually melting starter wires after months. Starter etc.. Once starter is worn it won't even turn the engine over.
Replaced all wires, starter, etc..
Problem is there but new stuff able to push thru the hard start..
Starter has heat shield per factory.
If I wait 5-10 more there is no problem starting ever, just that magic 7-10 time. Truck starts with a tap of the key
Any ideas or what should I look at next?
Old Sep 1, 2012 | 02:49 PM
montana_highboy's Avatar
montana_highboy
Sounds like classic starter heat soak, but you're running a heat shield
Did you replace the battery cables too? if not, what condition are they in? they can often times look fine but be corroded on the inside.
Old Sep 1, 2012 | 03:12 PM
spudgunman's Avatar
spudgunman
Full wire replacement on battery starter etc
Old Sep 1, 2012 | 03:44 PM
7636074460's Avatar
7636074460
hey i have the same symptoms on my 460, when i swapped carbs it didnt do it as bad, and i was thinkin the problem was it was getting flooded out, if i would hit it with starting fluid it would start, or just wait a long time and fire right off! also pumping the gas made the problem worse... someone told me the big-blocks would drip gas from somewhere and flood it when hot(doesn't sound like a possibility but made a good theory, never heard of it before)LOL. now that ive replaced all my carb mounting and spacer gaskets and rebuilt the carb i havent had too much trouble. my spacer gaskets were in really bad shape!
i do not have a heat shield either
Old Sep 1, 2012 | 04:02 PM
spudgunman's Avatar
spudgunman
Mine won't even turn over, like too much compression for the starter
A easy fix for yours is an aluminum spacer for the carb to intake.. Or try plastic.. But different issue.
Old Sep 1, 2012 | 04:08 PM
montana_highboy
Originally Posted by spudgunman
Mine won't even turn over, like too much compression for the starter.
Where's your initial timing set at? you may have too much advance which would exacerbate the situation when the engine is hot.
Old Sep 1, 2012 | 10:50 PM
spudgunman's Avatar
spudgunman
Dude I didn't even think..
Your spot on.. I am 99.9% sure you got it..
Thanks!
03DexterHauler
May 4, 2010 09:10 AM
Turbored
Sep 11, 2004 01:30 PM
pilot815
1978 - 1996 Big Bronco
Aug 25, 2004 04:13 PM
ScottInTexas
Apr 21, 2004 04:50 PM
cigarxtc
15
Jul 4, 2003 10:45 PM
