2wd front shock install
Old Sep 1, 2012 | 09:56 AM
timmyboy76's Avatar
timmyboy76
I know its a simple task, but was wondering, WHEN to stop the smashing of the bushings? Seems as though ,you can keep crushing it causing 1 side to have less of a "droop" then the other.
Old Sep 1, 2012 | 07:58 PM
F350-6's Avatar
F350-6
You want to compress them enough that you don't have a lot of travel of the bolt between the washers. They typically come with nylon or staked washers, so just tighten them up to where you see the rubber bushings compress good and call it a day. Maybe 20 - 25% compression or so. If one side is 1/4" different than the other, it won't hurt anything.
Old Sep 1, 2012 | 08:00 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
It's a bushing. It's job is to move, absorb and compress. You can't really hurt it. Tighten of down enough so the shock is secure, that's all you need.
Diesel and Steam
Oct 31, 2010 07:11 PM
XLnAK
Sep 25, 2009 10:23 PM
XLnAK
Oct 4, 2008 02:48 PM
TailGater_73F100
Jan 24, 2007 02:57 PM
blueeyes2478
Mar 9, 2006 05:47 PM
