Steering box interchangeabilty?
Old 09-01-2012, 07:49 AM
deere55's Avatar
deere55
deere55 is offline
I looked at the local junkyard for a steering box. They have one from a 92 F150, one from an 89 Bronco, and one from a 96 Ranger. Just wondering which if any will be compatible with my 91 F350.
They claim they all are, but I figured I would ask the experts not the salesmen. I haven't seen them yet, and they are all priced the same, so I figured I would buy the one of the best quality if they all will fit.
Old 09-01-2012, 08:31 AM
Puddy's Avatar
Puddy
Puddy is offline
I'll be honest anything safety I usually just bite the bullet and buy a new unit, so I really can't say if it will work or not, I suppose you could try and read the part #'s off the unit. Or try napa to do a cross reference between the units
Old 09-01-2012, 09:03 AM
mpc07005's Avatar
mpc07005
mpc07005 is offline
This will come up eventually, so I'll toss you the link now so it's easy to find: Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home
I really doubt the ranger box will fit, the 150/bronco (same truck, really) may, I haven't tried it before.
-Mike
Old 09-01-2012, 10:27 AM
deere55's Avatar
deere55
deere55 is offline
Thanks for the link, I added it to my favorites list of truck resources.
Old 09-01-2012, 11:07 AM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
My 89 Bronco2 steering gear box is the same as my both F250 trucks I have. A Ranger gearbox I took off matched up with the F250's but the E-series van steering boxes I think are diffrent. So allmost all of the years(80 to 96) F-series should be the same including newer Rangers and Bronco2's. I think even the 91 to 95 Explorers are the same too.
When getting a used steering box. Check the pitman arm output seal for leaks. That's a common failure but can be fixed with a kit that is out in parts stores(aprx $20). It replaces all the seals for the pitman shaft.
Old 09-01-2012, 03:59 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Yes, 80-96 F150,f250,f350 bronco, ranger, broncoIIs are all the same steering box
stephen.osborne1
08-07-2013 07:39 PM
mustange70
Offroad & 4x4
12-11-2005 02:13 AM
makemeknowit
1978 - 1996 Big Bronco
08-18-2003 08:08 PM
crazyhorse65
04-25-2000 11:08 PM
Quick Reply: Steering box interchangeabilty?
