Hate to do this but could not find info via search or manual
Do I check the oil when it's cold or hot?
I am assuming cold as then it would be fully drained into the pan
Thanks
Because of the difficulty of reading the dipstick I usually check my oil after the truck sits overnight. You can check it anytime as long as you can read the dipstick keeping in mind that oil expands some when it is hot. I think you will find your main problem is reading the dipstick no matter what time you choose. If you check it warm let the truck sit for a while and it wil make the process easier. One of my complaints about the truck is the dipstick.
I suspect the twisted metal dipstick is easy to read?
It is but having not held the new new cable style in my hand, I can't compare.
Cold, I can get two good readings (2nd, 3rd pulls) if needed.
It is difficult to get a level after a 30 min soak from running tho.
Reason: Edit...
It is very floppy as i mentioned earlier - pulls out easily but it is like pushing a rope going back in.
and due to some ****-retentiveness I did compare the actual dipstick reading area to that in the manual and they do match
