Almost there- diagnosing misfiring now
My 85 F250 w/ 460 and stock Holley...
Finally got her running yesterday, and now we are down to diagnosing a severe misfire. At idle it sounds like its got a high lift cam and I had to turn the idle screw all the way in to get her to idle without dying but the wider open the throttle is the more it smooths out.
I have already replaced the cap rotor plugs etc...
Yesterday while test running in the driveway (still not driveable, gonna be fixing the brakes today) it did smooth out and idle perfectly for about thirty seconds, then it ran out of gas. I put more gas in it and the misfiring was back.
I was gonna take a video for you guys but I couldn't figure out how to put my phone's cam in video mode. It was smoking, a mix of black and white which increased with more throttle until WOT, then the smoke decreased.
I'm not sure what else to look at since I already did the basic tune up stuff? Sorry if this is a stupid thread but I'm just not too familiar with these old carb'd engines...used to working on imports in which case I'd be plugging in a computer and diagnosing that way.
Ideas?
Ideas?
when i said idle screw i was referring to the one that pushes on the throttle linkage to make it idle higher...now i will need a quick how to on adjusting idle mixture screws where are they etc...sorry if it seems like im being retarded i just dont know anything about carbs..i did notice it pop/backfire a couple times while I had my foot about half into the throttle maybe a little less
Thipdar
04-15-2018 02:59 PM
LARIAT 85
20
11-10-2011 07:11 PM
mastaplan2k8
03-13-2009 12:34 PM
