Sponsored by: Auxito
Knocking
Old Aug 31, 2012 | 05:58 PM
Drilver's Avatar
Drilver
Knocking
My 2000 F150 started knocking, it does this after I get up to speed and let off the gas a bit, it will know as I push on the gas again but if I push heavy on the gas it dose not knock, What could if be? By the way it is a hard knock not a pinging sound.
Old Aug 31, 2012 | 07:27 PM
rsylvstr's Avatar
rsylvstr
you sure it's a knock and not the infamous exhaust manifold leak?
Old Sep 1, 2012 | 07:39 AM
enriched&beyound's Avatar
enriched&beyound
What is your oil level like? sorry but sometimes it is overlooked
Might be weak COP ( coil on plug), but this usually happen on light acceleration.
& agreed with rsylvstr could be cracked exhaust manifold too
Old Sep 1, 2012 | 03:34 PM
Bluegrass 7's Avatar
Bluegrass 7
My intuition is the cam chain guides are worn out.
Letting off the throttle causes the crank to change loading on the chains since they are geared to them.
If the tension is not being controlled, the chains just slap around against the front case cover.
You see; the tensioners are operated by oil pressure.
The chains run in non metalic guides.
When these wear down, metal is left besides chain slop.
Good luck.
BearNDownArchery
1997 - 2003 F150
May 11, 2012 07:13 PM
adam10
Mar 28, 2011 07:30 PM
Cory281
Nov 11, 2010 09:25 PM
Hendog
2004 - 2008 F150
Jul 22, 2009 10:04 PM
RustyFord88
15
Aug 14, 2008 07:47 PM
