boosting 32psi+??
Old Aug 29, 2012 | 07:37 PM
karthauler1's Avatar
karthauler1
boosting 32psi+??
bought this excursion, was getting very low response even when warmed up, took it off cleaned all the vains, some carbon but nothing crazy.. anyway i had never checked the boost level but now im going at 250kpa scanner does no read more wich is 36psi, consitent 41C air temp in 90F temperature outside.. stock is 25-28psi? whats up with mine.. all stock
Old Aug 29, 2012 | 07:42 PM
AGE mechanic's Avatar
AGE mechanic
If you are saying you are getting 32-36psi of Boost on a stock truck you better stay off that go peddle until you find the issue.
Old Aug 29, 2012 | 07:50 PM
karthauler1
well all i know is i have the cat stock exhaust, no delete etc, could there be a program? can it be seen thru the scan, what could cause the overboost is the question, not like it has a wastegate...
Robert6401
Dec 13, 2013 06:45 AM
fordman67
Oct 12, 2012 12:03 AM
bigmacmonday
22
Feb 18, 2012 10:34 PM
1967 Turbo 6.9
Dec 6, 2007 06:45 PM
bhd
Sep 19, 2005 11:24 PM
