Sponsored by: Real Truck
A/C question
Old Aug 29, 2012 | 11:18 AM
jed1894's Avatar
jed1894
A/C question
I just bought F350 that was used on a farm. That means it's rough.....windows down, around grain bins, in the field in the dust, etc. I have an air condition problem. The A/C blows cold, but down not blow hard enough. The control says wide open and the fan sounds like it's wide open, but it's blowing about like it was let to the lowest speed.
So, before I take it in I was going to see what you guys thought. Here's my thought and/or question: I was thinking of taking an air compressor and blow down the vents or blow under the dash....or find the fan and blow it out. Any other suggestions or comments?
Here's what I have done so far:
1. Checked the air filter (the gauge on the side says it's okay). I have not taken it out and looked real close. Could that be causing the problem?
2. Pressure washed the radiator.
Ford says it's the evaporator coil, which is a $900 project since it's behind the dash. I'm trying to trouble shoot before that happens.
Thanks, John
Old Aug 29, 2012 | 01:07 PM
projectSHO89's Avatar
projectSHO89
Most likely, the evaporator core is dust-choked.
Remove the blower motor and clean the core as much as possible.
Old Aug 29, 2012 | 03:26 PM
jed1894's Avatar
jed1894
You wouldn't have any instructions for this procedure would you? Any help on how to do this would be very much appreciated. Jed
Meatus
May 6, 2019 02:49 PM
SC_Dave
Oct 2, 2016 01:11 PM
bradpowell3557
31
Sep 15, 2014 03:03 PM
OldRed4X4
1983 - 2012 Ranger & B-Series
Feb 17, 2009 07:43 AM
Rick_Ford
Jun 10, 2003 04:49 PM
