clunking from rear end when turning corners with bumps only.
..when I turn over bumps not on corners I hear nothing lol ..I just changed the tie rods for other reasons and nothing is loose in the front end now..But this sound is from the box of the truck like something is in the box bumping around when turning corners over bumps..Its frustrating and I cant find out what it is..Only happens when turning over bumps ?
Steve, it would be nice if you told us what bicycle your have and how big the pedals are.;
Year and motor, 2wd or 4wd please!
When was the last time the rear discs or drums were taken 'off'?
I found out its the box bumping against the frame because a few of the nuts and bolts are loose and or missing that holds the box on lol Going to have to go to wreckers and find some if I can figure out how to put them on, it looks tricky with the frame in the way...its a 1999 ford f350 diesel 7.3 4x4 by he way..thanks for reply's guys
For every one, please do some checking on your issues before posting a thread.
It you don't, all it is is a lot of guessing for naught as happened in this thread.
Thanks.
