Chassis/Cab Swap Question
Old Aug 27, 2012 | 12:20 PM
blueoval65's Avatar
blueoval65
I found an early 80's ford with 300/4sp. Truck runs & drives good, but a tree fell on the cab. Its real cheap. I was thinking about a swap to put a 67-72 body on this early 80's chassis. But this raises a few questions:
1. Would these trucks' cab mounts match up?
2. Will bed / hood & fenders bolt on?
3. If they do match, what would be the most common problem with the swap?(ex. fuel filler, wiring) I understand there's a list of things as long as my arm that could go wrong. But curious about specific problems of marrying these two model trucks.
I'm halfway hoping one of y'all tell me this is one of the dumbest projects I could ever take on. Please, someone talk me out of this.
Thanks for your time.
Later
Old Aug 27, 2012 | 06:23 PM
83capril's Avatar
83capril
Just get a cab from a 1980-1996 (1997 F250HD-350). I may be wrong but the frames on the trucks you are looking at are narrower then ours. Also you would have to do some fab work. Sounds like it could be a sweet project.
Old Aug 27, 2012 | 07:05 PM
86fordtruck's Avatar
86fordtruck
Hey blueoval,
Why not take that sweet running 300 and 4sp tranny and swap them into the older truck. Although the cab swap may seem simple, all the little details do tend to sneak up on you.
Good luck,
Old Aug 27, 2012 | 07:40 PM
Franklin2's Avatar
Franklin2
They won't fit. Like was said, the frames are wider on the 80-up trucks.
Old Aug 27, 2012 | 07:57 PM
blueoval65's Avatar
blueoval65
Thanks guys. This is the great information I come to this website for. Really like the idea of pulling motor/trans for older truck.
Later
Notmeofficer
Apr 20, 2014 08:53 AM
3360stepp
Sep 19, 2010 09:52 PM
65mustang
Nov 11, 2004 01:07 AM
bigblock466
Oct 18, 2004 04:41 PM
PowerbyFord
Mar 20, 2003 06:12 AM
