Transmission Question
Old Aug 26, 2012 | 07:38 PM
Boatbum01's Avatar
Boatbum01
I was recently pulling a gooseneck trailer, and I had the OD off, and on mostly city streets. I had only went about 2 miles and had to stop at a stop light. The truck wanted to keep going as if a manual transmission and I had not pushed in the clutch, it was bucking and finally quit. When the light changed it went through the shifts normally. I have the automatic. I had not gone over maybe 40mph of maybe less. Today I pulled the same trailer back to where I borrowed it and this symptom occurred again. Could it be the torque converter locked up and not unlocking when I was slowing to a stop? If so, what do I need to do? Or alternately, what else could cause this? I have about 129k miles on the clock, and normally I don't haul anything. I would appreciate any and all suggestions or remedies.
Thanks,
Jim Monahan
Jmonahan43@gmail.com
Old Aug 26, 2012 | 07:46 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Best thing to do is to get the codes read and see if anything shows up. With our trucks you will need to either A) take it to a shop, or B) find someone with the Ford Enhanced Auto Enginuity tool. I had a member on here help me out years ago with some live datalogging and he wouldn't take cash, so I treated him to dinner each time he helped me out. Shop charges are $75 or more for one scan. Dinner cost me $60ish and I made a new friend. Helluva deal.
Old Aug 26, 2012 | 09:14 PM
BigAlsPSD's Avatar
BigAlsPSD
Where in NW arkansas? I am in Pea Ridge, Bentonville, Rogers Area, and could scan it for you.
Old Aug 26, 2012 | 09:44 PM
Bonanza35's Avatar
Bonanza35
Sounds like the torq convertor didn't unlock unless you foot hit the throttle the same time it hit the brake. It dose happen. That said, do you have a lock up switch for the convertor that was left on. Have it scaned, that should tell the story. I never heard this one before, but have heard people, even me, stepping on the throttle at the same time.
Old Aug 26, 2012 | 09:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Your torque converter is locking when it shouldn't be locking. There are several things that can cause that.
Low trans fluid
Loose/missing internal filter
Sticking torque converter control valve
Sticking torque converter clutch solenoid
Short in the wire to the torque converter clutch solenoid
Worn seals
Weak/worn pump
Bad torque converter
Old Aug 26, 2012 | 09:50 PM
Boatbum01's Avatar
Boatbum01
Re: Transmission Question
I did not step on the throttle and brake at the same time, and No I do not have a switch to lockup the torque Converter. I was only moving about 10 mph and gradually braking when I experienced this.
Can a Ford dealer do the scan? I hate to go to them. I am in Albuquerque, NM so I would appreciate it if anybody has info on a shop that can scan it. I just moved here so I haven't had a chance to make any contacts with shops.
Thanks,
Jim
Old Aug 27, 2012 | 05:35 AM
Mark Kovalsky
Yes,, a Ford dealer can do the scan.
Frank250Tank
Jul 1, 2016 07:12 AM
clemensfield
Jun 27, 2013 09:06 AM
ssjerrys
Oct 20, 2010 10:19 PM
grantorino
May 8, 2009 12:07 AM
