Alternator Upgrade Amperage Question
Another question- I am about to replace my alternator but Napa offers several different models that will physically fit, but all with different outputs. The options are 38, 55, 65 amps output. Is there a downside to installing a high rated alternator? Specifically, if I install the 55 amp unit, will it fry the fusible links or parts of the wiring harness?
-Mike
-Mike
Don't waist your money. Do a 3G 130A upgrade. You can get the stuff out of the junk yard and be into it less than $100. Usually much less. I'm getting ready to do it myself.
https://www.ford-trucks.com/forums/9...g-upgrade.html
Last edited by GOVTMOD; 08-26-2012 at 08:41 PM. Reason: correct smartphone screw ups and post link.
