Rear axle?
Old Aug 26, 2012 | 03:51 PM
j250hd's Avatar
j250hd
Rear axle?
Is there a way to fill the differential up without removing the cover?
Old Aug 26, 2012 | 03:55 PM
427 fordman's Avatar
427 fordman
There is a fill plug on the drivers side of the center section. No drain plug though.
Old Aug 27, 2012 | 07:19 AM
DIYMechanic's Avatar
DIYMechanic
Pull the VSS out of the top of the axle and fill it through that hole. It is a lot easier than trying to fill through the fill plug. Take the plug out anyway though so you know when it gets full.
If you're asking whether there is a way to drain it without pulling the cover, unless you have an aftermarket cover with a drain plug, then no. There isn't.
walkerfarms
Oct 27, 2019 09:29 AM
eraser5
Sep 17, 2010 09:08 AM
hdrdrntn
Apr 22, 2010 08:57 PM
izmepeggy
Sep 13, 2008 07:26 PM
masterp2
Jun 24, 2004 08:58 PM
