No flashers
Old Aug 26, 2012 | 02:15 PM
Doctomario777's Avatar
Doctomario777
No flashers
I'm at a bit of a loss here... I might just have to break down and take my truck into the shop. Since I bought the truck I haven't had turn signals. I realized the turn signal switch was bad and swapped it out; now my brake lights get brighter depending on the corresponding side I select with the turn signal, but the flashers still don't blink. I also don't have any dash indicators and my hazards don't work either. I replaced the fuse and the flasher relay. Haven't replaced any bulbs, but none of the lights work... front or back. It doesn't seem likely that all 4 bulbs would be burnt out to me. Any thoughts on where I should go with it next?
Old Aug 26, 2012 | 06:11 PM
projectSHO89's Avatar
projectSHO89
...if only we knew what you're working on. Perhaps positive identification of your vehicle would be the next thing to do.
Old Aug 26, 2012 | 07:03 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
His profile says 2001 F250.
Old Aug 26, 2012 | 08:06 PM
Franklin2's Avatar
Franklin2
Do the front bulbs get brighter like the rear ones do?
Old Aug 26, 2012 | 08:34 PM
Doctomario777
It's actually a 78 f100. Not sure if the front headlights illuminate like the rear ones or not.
Old Aug 26, 2012 | 10:33 PM
critterf1's Avatar
critterf1
Front and rear headlights? I just had to ask.
Old Aug 27, 2012 | 11:42 AM
Franklin2's Avatar
Franklin2
Check if the front lights get bright but don't blink.
Doctomario777
13
Aug 26, 2012 10:01 PM
cliffordingles
16
Nov 1, 2011 05:00 PM
reddogforge
Jun 10, 2010 10:46 PM
gt8684
Sep 18, 2009 03:04 AM
574MF4
1997 - 2003 F150
Dec 7, 2005 05:50 PM
