Offroad & 4x4
Efi issues
Old Aug 26, 2012 | 10:22 AM
Bender99's Avatar
Bender99
Efi issues
I swapped the cab on an 88 f250 with a 460 and auto trans and now can't get anything but lights and gauges to work. Fuel pump won't run with key foreword and it won't turn over by the key. I swapped the computer and most of wireing from original truck. The cab I put on it is from 91 truck with a 302 and 5speed, I knew id have to do something with clutch safety switch/nuetral safety but figured the fuel pump would turn on with the key foreword before I hit that problem. Could the column itself be screwing me? Or maybe missing a ground somewhere?
Old Aug 26, 2012 | 12:30 PM
captain p4's Avatar
captain p4
Did you check fuses/relays? Trace the wires from the fuel pump and make sure everything is right?
Old Aug 26, 2012 | 01:25 PM
joe f350's Avatar
joe f350
is it a auto tranny or manuel
Old Aug 26, 2012 | 03:57 PM
alpha/omega's Avatar
alpha/omega
I will sell you a custom Left Eye Blind Racing and Fabrication neutral safety switch delete for $19.95. + s&h. Choice of wire color at no additional charge.
Captainp4 has been a satisfied customer for a couple months now as well as hundreds of other customers around the world
Old Aug 26, 2012 | 05:10 PM
captain p4's Avatar
captain p4
He might even throw in a sticker with it.
And show up at your house to consume massive amounts of alcohol.
Old Aug 27, 2012 | 06:10 PM
Bender99's Avatar
Bender99
I checked fuses, didn't get into relays. Everything worked fine before I swapped cabs. Seems like the computers not getting power. Has anyone seen any good write ups for efi 460 wiring? I wouldn't mind getting rid of all the wiring that doesn't make the motor run.
Old Aug 27, 2012 | 07:53 PM
77mud's Avatar
77mud
Rip it all out by my extra set of D3 heads and extra intake/carb rip all the wiring out in a MSD box and let it eat...
Old Aug 28, 2012 | 03:46 AM
alpha/omega
Thats the easy way to do it.
Old Aug 28, 2012 | 06:43 AM
hav24wheel's Avatar
hav24wheel
What did you do with the wiring for the trans? Without knowin what you kept, and what you didn't, trans wiring is my best guess.
It took me the better part of a sat to pull ALL the unneeded wiring out of my old 94 when I swapped that to a carb. It's a very involved process.
Old Aug 28, 2012 | 04:49 PM
77mud's Avatar
77mud
hence why carb would be the easy option....
Old Aug 28, 2012 | 05:35 PM
hav24wheel's Avatar
hav24wheel
He still would have to fix the issues he is having If he switches to a carb....
Old Aug 28, 2012 | 05:51 PM
77mud's Avatar
77mud
True for some reason i was thinking i had read it had a 5spd.... wrong thread
Bigdaddy2975
2004 - 2008 F150
Jul 7, 2018 02:21 PM
xfrog
Dec 3, 2014 07:56 PM
wrenched
Nov 27, 2008 03:46 PM
mislotis
17
Jan 4, 2005 11:13 AM
79F150400M
General Automotive Discussion
Mar 14, 2004 12:34 PM
