I swapped the cab on an 88 f250 with a 460 and auto trans and now can't get anything but lights and gauges to work. Fuel pump won't run with key foreword and it won't turn over by the key. I swapped the computer and most of wireing from original truck. The cab I put on it is from 91 truck with a 302 and 5speed, I knew id have to do something with clutch safety switch/nuetral safety but figured the fuel pump would turn on with the key foreword before I hit that problem. Could the column itself be screwing me? Or maybe missing a ground somewhere?
I will sell you a custom Left Eye Blind Racing and Fabrication neutral safety switch delete for $19.95. + s&h. Choice of wire color at no additional charge.
Captainp4 has been a satisfied customer for a couple months now as well as hundreds of other customers around the world
I checked fuses, didn't get into relays. Everything worked fine before I swapped cabs. Seems like the computers not getting power. Has anyone seen any good write ups for efi 460 wiring? I wouldn't mind getting rid of all the wiring that doesn't make the motor run.
