Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
EVAP Vent Valve Test?
Old Aug 25, 2012 | 10:03 AM
jhid101968's Avatar
jhid101968
Hi,
I put a 12V source to my canister vent valve ('02 Escape) to see if is working.
I here clicking, but should I be able to see the plunger move?
Also, how can I test the purge valve?
Thanks.
Old Aug 25, 2012 | 10:30 AM
wptski's Avatar
wptski
Hand pump like a MityVac w/wo power to it.
Old Aug 25, 2012 | 11:43 AM
jhid101968's Avatar
jhid101968
Thanks, Bill.
Can you explain the steps involved to do that with a vacuum?
Old Aug 25, 2012 | 12:02 PM
wptski's Avatar
wptski
Originally Posted by jhid101968
Thanks, Bill.
The valve is normally open or closed like switch. If you connect the hand vacuum pump to either port, it'll hold vacuum or not. Put 12V to it and if it doesn't change its state, it's bad.
If you can get some kind of hose that you can blow into it, you may not need a hand pump although it'll be a lot easier. Since it works with vacuum, it would be better to use vacuum instead of pressure.
Old Aug 25, 2012 | 12:15 PM
jhid101968's Avatar
jhid101968
Thanks Bill! I'll try that and report back to you with the results.
Old Aug 25, 2012 | 09:27 PM
jhid101968's Avatar
jhid101968
Bill,
I just saw in my shop manual, something that no one has ever mention,
FVV (FUEL VENT VALVE).
Does anyone know how this valve functions? Do these valve ever go bad.
Do these valve function in a similar way as a vacuum breaker (will it let air into the tank, (because the tank goes under vacuum you burn fuel off)?
And/or doe the FVV,function as an over pressure relief valve, e.g., if you have the car park out in a hot day does it vent the vapor somewhere tp relieve vapor pressure in the fuel tank.
Could a bad FVV cause a po455 code?
Thanks!!
Old Aug 26, 2012 | 07:38 AM
wptski's Avatar
wptski
Bill,
Thanks!!
If it's part of the EVAP system, yes. Google "Ford DTC P0455".
Old Aug 26, 2012 | 05:44 PM
jhid101968's Avatar
jhid101968
Is there anyway I could hook up the jump wires to test the purge valve backwards and short something out ?
Thanks!
Old Aug 26, 2012 | 09:24 PM
wptski's Avatar
wptski
Thanks!
Not sure what your asking.
Old Aug 26, 2012 | 09:56 PM
jhid101968's Avatar
jhid101968
If I hook up the positive and negative test wires from the battery (12V source) to the 2 prongs on the purge valve electrical connection wrong (like, only the positive test wire the the right prong) could you ruin the purge valve?
Old Aug 26, 2012 | 11:31 PM
Torky2's Avatar
Torky2
Possibly, if the back-EMF diode is part of the valve solenoid assembly, instead of in the ECM.
The 2010 (many years later!) shows that the purge valve has 12 volts on one side (harness wire color Green) and the other side (harness wire color white-Brown) runs off to the ECM. To open the valve, the ECM applies a ground to the White-Brown wire. The colors may be different in yours, but you could check for what the proper operating polarity on yours should be.
If yours uses the same circuit topology, i.e., positive battery on one side, ECM applies ground to other side, you can:
Disconnect connector from purge valve.
Turn ignition to RUN.
Check each of the two harness wires one by one with voltmeter, with the other voltmeter probe on a good ground. Whichever of the two wires has 12 volts on it, that is the wire that goes to the purge valve pin that should be positive when you power it externally. By default, the other purge pin goes to negative.
Old Aug 27, 2012 | 07:55 AM
wptski's Avatar
wptski
You've unplugged the valve so it's imposssible to damage the PCM and polarity doesn't matter on the valve.
On a '09, a GN wire has the 12V and the WH-BN goes to the PCM. Your best bet is to use a hand vacuum pump, power the valve, see if its working and go from there.
Old Aug 27, 2012 | 09:01 AM
Torky2's Avatar
Torky2
Bill,
My 2010-model info has polarity markings on the schematic for the solenoids controlled by the PCM. I thought that was unusual. I don't know why, that's why I wondered if they moved the back-EMF diodes from the PCM out to the individual solenoids. Having them out at the source of the di/dt would reduce the sharp transient that would occur through the harness wiring as when the diodes were in the PCM front end. If one in testing the solenoid valve applied a current-unlimited source backwards to the diode (if it was indeed in the solenoid valve), it would forward bias it, destroying it.
Another possibility with the polarity marking is that they are using a magnetized core to reduce the current required to operate/hold them, reducing power consumption/power handling/heat in the PCM. Or maybe somebody just liked polarity symbols to be complete!
I really don't know which, and a 2002 could be completely different.
Old Aug 27, 2012 | 12:58 PM
wptski's Avatar
wptski
Originally Posted by Torky2
Bill,
I thougth that those diodes had to be at the coil itself? I noticed that on a A/C compressor clutch on a old Buick I was working on.
Old Aug 27, 2012 | 01:54 PM
projectSHO89's Avatar
projectSHO89
Electrically, it doesn't matter. It can be anywhere in the circuit as long as it's in parallel with the coil. It's there to protect the driver electronics from spikes when the coil's electrical field collapses and induces "back -EMF" into the circuit. The diode shorts that spike to ground.
