Sponsored by: Auxito
'01 f150 sputtering
Old Aug 24, 2012 | 11:10 PM
vegasford's Avatar
vegasford
'01 f150 sputtering
it started sputtering at random times a few days ago and the check engine light came on. the two codes are p0401 (blocked egr syatem) and p0402 (egr valve stuck open). it seems to do it most when it's cold but some days itll do it non stop. please let me know if you've had the same problem or know how to fix it thank you!
Old Aug 25, 2012 | 12:55 AM
Bluegrass 7's Avatar
Bluegrass 7
Those codes are oppisite each other in testing.
401 is a low flow test failure.
402 is an excessive flow test failure.
I would be first looking at the vacuum regulator for sticking.
It's used for both tests and all operations of the EGR system.
Follow the hose from the EGR back to the vacuum regulator.
Remove it and spray clean inside with throttle body cleaner.
Take the round CAP off the top and clean the filter inside it.
See if this fixes the problem.
Good luck.
Ford Breakdown
1983 - 2012 Ranger & B-Series
18
Nov 4, 2013 05:03 PM
billyboycurran
1997 - 2003 F150
Jan 27, 2011 09:28 PM
BCHauler
Oct 2, 2008 04:27 PM
SpicyChxTacos
Nov 23, 2004 03:34 PM
brannma
Aug 25, 2003 07:25 AM
