Brakes
Old Aug 24, 2012 | 03:56 PM
77 2wd's Avatar
77 2wd
Brakes
I went to swap my truck to PB, i added the circular booster to the firewall then the master cylinder on top of it, hooked the little rod with the circular thing up to my brake, but the brake has no power to it, and the cylinder is full of fluidd, i push the pedal it has no power and it wont return, any advice? the Pb i got was off of my 78 f150 i put it on my 77 f100
Old Aug 24, 2012 | 04:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Is the vacuum line hooked up? And did you bleed the brakes after installation?
Old Aug 24, 2012 | 06:12 PM
77 2wd's Avatar
77 2wd
yeah, and no, didnt think i needed to since the cylinder and lines were already full?
Old Aug 24, 2012 | 06:30 PM
HIO Silver's Avatar
HIO Silver
So lemme see if I understand correctly... you simply slid the booster btwn the MC and the brake pedal without disconnecting the hardlines from the MC, right?
Old Aug 24, 2012 | 06:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Did you change the brake pedal when you made this swap?
1973/79 F100/350: There are TWENTY TWO different brake pedals, NINETEEN different power brake boosters, SEVENTEEN different master cylinders and SEVEN different clutch pedals, I kid you not!
Whatever you took the booster from, you need the brake pedal that matches it.
Old Aug 24, 2012 | 06:48 PM
f5fordgirl's Avatar
f5fordgirl
Are you sure the little rod that operates the master cyl stayed in the booster? That rod is adjustable, and needs to be adjusted to the proper length to make the master cyl work.
Old Aug 25, 2012 | 02:36 PM
77 2wd's Avatar
77 2wd
No i did not, ill try that
Old Aug 25, 2012 | 02:38 PM
77 2wd's Avatar
77 2wd
It did stay in but i didn't adjust it??
bulldog1064
15
Dec 27, 2011 06:17 PM
osufireman
Bronco II
Apr 6, 2010 10:02 PM
jmkelly
May 18, 2009 11:44 PM
65fordguy
Nov 5, 2008 10:23 PM
The67Beast
Jul 27, 2007 12:42 PM
