what axle do i have
Old Aug 24, 2012 | 12:37 PM
joeycyph56's Avatar
joeycyph56
what axle do i have
I have a 04 e 350 sd cutaway with drw 158" wheelbase.what differential do i have in it? I know its a 4.10 ls. Axle code is E2.what dana # could it be and is there a different cover i can put on it cause the stock one is rusted to ***** and leaking.on my 250 i replaced the stock cover with the aluminium stock one due to same reason.thanks
Old Aug 24, 2012 | 11:49 PM
powerstroke72's Avatar
powerstroke72
Moved to the correct forum.
Old Aug 25, 2012 | 12:23 AM
95e150CW's Avatar
95e150CW
Should be a Dana 70U. Super slim chance it could be a Dana 80 depending on what your cutaway was ordered to become (RV, Commercial Truck, Special Service, etc). Should be stamped on the front passenger side of the diff. You should get the BOM number off the tube, and check before ordering a diff cover. Ford had some odd combos available, including a Dana 60 carrier in a 70 sized housing, which used a different cover.
Old Aug 25, 2012 | 06:56 AM
joeycyph56's Avatar
joeycyph56
Ok thanks. Any thoughts on which company i should look at for a cover? I usually do low miles around town.
Disordinate
Jan 31, 2018 04:09 PM
bremen242
Offroad & 4x4
60
Aug 27, 2011 11:25 AM
BigWhite94
Sep 4, 2010 12:29 AM
66F100Again
Mar 12, 2008 06:14 PM
mizzitch
Mar 29, 2006 11:36 PM
