2003 Ranger Supercab - CD Player Load Error
Old Aug 20, 2012 | 05:10 PM
shcolwell's Avatar
shcolwell
I just purchased a used 2003 Ford Ranger Supercab and have a problem with the 6-disc CD Player not loading cds. There are NO cds in the player and when you try to load one it states "LOAD ERROR" even for every slot that you choose. Any help in resolving this issue would be appreciated.
Old Aug 20, 2012 | 05:55 PM
Furyus1's Avatar
Furyus1
Could be any number of issues. Dust can keep the laser from reading the disc - this can sometimes be remedied with blowing it out with canned air. The loading mechanism can cause issues if it's not "grabbing" the disc well enough to load it all the way. A sensor might not be working right. It's sometimes difficult to tell what's going on unless you tear it apart and look...
I'd start with blowing it out with air and see if that does anything...
Old Aug 23, 2012 | 11:42 AM
shcolwell's Avatar
shcolwell
Terry, thanks for your help. The canned air did the trick. I sprayed the air in for 10 to 15 seconds and then inserted the CD. It did not work right away , but after repeating this procedure a couple times it worked. Thanks again for the suggestion. SHC
Old Aug 23, 2012 | 06:44 PM
Furyus1's Avatar
Furyus1
No problem. Glad to hear it was something simple.
Old Aug 26, 2012 | 10:02 AM
grandmas77f150's Avatar
grandmas77f150
Lucky you, the changer went out on mine, the cost to fix it was more than the cost of a top of line Kenwood receiver
Upper90dcm
Mar 10, 2008 09:39 PM
SMIGGS
1997 - 2003 F150
Jul 27, 2007 11:05 AM
purduefan
19
Apr 13, 2004 11:14 PM
bwmyers18
Nov 1, 2003 06:58 PM
