Remove DEF System only without Tuning?
Old Aug 22, 2012 | 12:06 AM
Chad149's Avatar
Chad149
Originally Posted by B&LLandscaping
I just read on another site that it might be possible to run only distilled water in the DEF tank rather than DEF. No more DEF to buy and hopefully no more acrid ammonia smell. There was no detail or follow up on it though, so I'm not sure it's even possible or what the risks would be and figured this was the best place to ask.
I can't see how the truck's computer would know the difference and I can't see how it would negatively affect the exhaust, in fact, it seems just crazy enough to work lol.
Anyone tried this? Thoughts?
This did work on 2009-2010 Mercedes diesels-would keep the def system happy (and vehicle going down the road) but you would have a CEL because nows theres no urea to break down the NOX and, well thats the point of a nox sensor is to see that the job is getting done. Software was changed(and recall issued) to that after a def refill ecu had to see the def system working to even acknowledge it was filled. If our Fords are the same (Bosch supplies both injection systems), theres no actual sensor, "contanimated def" message is what the ECU spits out when all its eletrical inputs and outputs seem fine to it but not seeing needed results from the nox sensor.
Old Aug 24, 2012 | 10:30 PM
BrockwayMT's Avatar
BrockwayMT
Seems like a lot of effort just to remove DEF/SCR. If you are going to throw your warranty and do that much messing around you might as well get rid of the DPF and the EGR too. At least that way you'll get some mpg to offset your money and effort in desmogging.
Nearly Normal Mike
Oct 4, 2014 08:59 AM
radzer0
6.7L Power Stroke Diesel
16
Jun 24, 2010 11:24 PM
kmaplf
Oct 7, 2007 05:19 PM
lostbuckaroo
Dec 30, 2003 02:22 PM
billytucker1
Nov 18, 2002 09:22 PM
