High fuel pressure?
Old Aug 20, 2012 | 11:28 AM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
High fuel pressure?
Hey guys! So my current situation is this: the other day I just started up my truck and took off down the road. Didn't think it should warm up since it was about 70 degrees outside. I get about a mile down the road, and it starts actin like it was choking. Lost power, and it would die if I hit the clutch. Wouldn't turn over with cranking, and if I clutch started, it would only stay running until I hit the clutch again. This whole time there's a huge cloud of white smoke pouring out of the exhaust, so thick I couldn't see anything else in my mirrors. I pulled into a parking lot and it died, so I sat there and cranked for a good minute (with breaks every 15-20 seconds so I didn't overheat the starter). Finally got it to turn over, and just say there idling for about 10 minutes. After that it ran fine, but now my fuel pressure gauge is maxed all the time. Come payday I'm replacing the filter, but I'm wondering if maybe there's a blockage in the fuel system somewhere? What do you guys think it sounds like?
Btw, I know it has at least 2 bad glow plugs, you think that might be a factor?
Old Aug 20, 2012 | 02:06 PM
DIYMechanic's Avatar
DIYMechanic
When you say it "wouldn't turn over with cranking" do you mean that it wouldn't crank the engine over or just that it wouldn't start?
Old Aug 20, 2012 | 03:26 PM
f350rebel7788
Yeah, that was a little vague, sorry. It would crank, but wouldn't start.
Old Aug 20, 2012 | 03:35 PM
Hussler's Avatar
Hussler
My first thought is you bent a push rod but seems the problem went away, so ... , then you mentioned high fuel pressure.
I would check the fuel pressure with a stick gauge just to verify.
Old Aug 20, 2012 | 03:39 PM
f350rebel7788
Yeah, it hasn't done it since, but my fuel pressure gauge is still maxed ever since then. I'll stick a stick gauge on there and double check though. After all, they're glow shift gauges, so it may be possible it just don't work... Lol
f350rebel7788
Nov 23, 2011 11:40 AM
Reticle
Modular V10 (6.8l)
Oct 28, 2010 11:06 AM
Tim Young
Apr 19, 2010 05:36 AM
roadking334
Feb 4, 2009 07:40 AM
bradleyj
Sep 14, 2007 10:04 PM
