Small irritating problems I need help on
Old Aug 19, 2012 | 09:58 PM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
First: Odometer lights go out a lot.
Second: Cruise Control light just went out
Third: In Dash cup holder spring came loose from the 2 plastic nibs.
Is there a fix for any of these?
Old Aug 19, 2012 | 10:40 PM
EcoBoostExpedition's Avatar
EcoBoostExpedition
First and Second: Need to pull apart the dash and solder new LEDs in the dash on the logic board.
Third: damn good question, good luck!
Old Aug 20, 2012 | 05:50 AM
alwaysfords41's Avatar
alwaysfords41
There is a thread here for the odometer - search "odometer blackout problem fixed" and you will find it. You need to pull the cluster, and resurface / remelt a few cold solder joints. The write up is good with pics and all.
Old Aug 20, 2012 | 12:36 PM
kailor's Avatar
kailor
My in-dash cupholder spring kept coming off so I removed it from the dash and used a small screw (1/4" long?) to hold it in place. It has performed flawlessly for 6-7 years. Going from memory here...
1. Remove cup holder (I think there is a courtesy lamp attached somehow)
2. Take spring (this is not a coiled spring but more like a thin strip of metal that functions just like a coiled spring) to workbench and drill small hole through middle of spring (equidistant from each end and each edge) AND drill small STARTER hole into cup holder
3. The more bend in the spring, the faster it'll pop out of the dash when you push in on it to get it out of the dash (you can experiment with this)
4. Mount spring to cup holder (the screw, through the spring, and into the plastic of the cup holder (don't over tighten so as to wallow out your hole in the plastic cup holder)
5. Reattach courtesy lamp
6. Reinstall cupholder into dash
7. Place beverage of your choice in cup holder
8. Enjoy beverage
Search this forum for: "2001 in-dash cup holder spring"
Old Aug 21, 2012 | 05:54 PM
NorthCarolinaExpy
Thanks gang for the help on these. I'll try to post some pics of my progress.
Old Aug 25, 2012 | 11:11 AM
NorthCarolinaExpy
Progress made with the in dash cup holder. Drilled a hole in the existing plastic pop rivets and installed two screws.
The little LED is not lighting but I couldn't get it loose to change it out. Anybody know how to change those lights out. I didn't want to break the electrical connector inside the dash area.
[IMG]<a href="http://s1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/?action=view&amp;current=EXPEDITIONREPAIR007.jpg" target="_blank"><img src="http://i1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/EXPEDITIONREPAIR007.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/?action=view&amp;current=EXPEDITIONREPAIR006.jpg" target="_blank"><img src="http://i1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/EXPEDITIONREPAIR006.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/?action=view&amp;current=EXPEDITIONREPAIR005.jpg" target="_blank"><img src="http://i1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/EXPEDITIONREPAIR005.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/?action=view&amp;current=EXPEDITIONREPAIR004.jpg" target="_blank"><img src="http://i1099.photobucket.com/albums/g388/JEltonJ/EXPEDITION/EXPEDITIONREPAIR004.jpg" border="0" alt="Photobucket"></a>[/IMG]
chardagha
1997 - 2003 F150
May 26, 2015 11:48 PM
dadgonebroke
Jun 8, 2013 08:29 AM
crabjoe
Sep 21, 2011 11:02 AM
vallenwood_1
1997 - 2003 F150
Jun 3, 2009 10:57 AM
rhino_160
Dec 23, 2007 10:35 PM
