Front axle questions
Old Aug 19, 2012 | 09:42 PM
robs01f250's Avatar
robs01f250
I recently had some noise coming from the front end and finally got a chance to look at it today. Well it turned out I needed new wheel hub assembly's on both sides as the wheels had play when jacked up off the ground. After getting them replaced i took it for a drive and still heard something in the front drivers side. Got back under the truck and grabbed the front driver side u joint and could move it up and down and was making a clunk sound. I can grab the knuckle that is part of the axle shaft and move it as well. My question is, "is this just a j joint problem or something more?"
Pro2ndAm lib.
1997 - 2003 F150
Jul 8, 2016 09:23 PM
ethand320
1997 - 2003 F150
Feb 27, 2014 09:41 AM
chris_wei17
Dec 12, 2012 03:37 PM
