idle overheating
Old Aug 19, 2012 | 05:06 AM
ford303's Avatar
ford303
idle overheating
i have a 1994 ford 300 inline six e4od. And when it sits there and idles it starts to over heat. The temp gage will get to the a in normal. Well i replaced what i thought was the sending unit in front of the motor around where the water pump is. But that wasnt it. THe truck will go it high idle and everthing. It was a brand new rad in it and thermo. Is this a common problem or do i need to look at getting the block flushed. By the was the truck has 231??? miles on it
Old Aug 19, 2012 | 09:25 AM
Harte3's Avatar
Harte3
You would best get a definitive reading of the actual temperature which is something you won't get with a stock gauge.
Old Aug 19, 2012 | 02:22 PM
Truckin Bob's Avatar
Truckin Bob
(In bold) That item you replaced was the sending unit for the computer only, not the guage in the instrument cluster.
The one for the guage is located on the passenger side of the motor near the firewall.........PITA to get to and change (in my opinion).
Bob
Old Aug 20, 2012 | 08:58 PM
yorska's Avatar
yorska
does the temp go back down when moving? If it does then change the fan clutch. Fairly common for them to stop working after a while and not too hard to replace. Main symptoms of one failing are temp climbing when sitting still or going slow but sitting normal when going faster like on the highway(over about 40ish).
You are supposed to be able to check them by comparing the resistance to spining the fan by hand between with the engine cold and hot. Free spin cold to resistance when hot. Engine off, of course. But if the temp is acting like I described earlier, I would just change the clutch.
Old Aug 22, 2012 | 01:34 PM
rustywheel68's Avatar
rustywheel68
How old is the water pump?
Old Aug 22, 2012 | 01:56 PM
willowbilly3's Avatar
willowbilly3
Is it pushing out coolant when it "overheats"? In my opinion, you don't have a heating problem if the coolant is staying in the engine.
Did you burp the air out of the system when you changed out those parts? If not, that's the first thing to do.
Old Aug 25, 2012 | 11:48 AM
ford303's Avatar
ford303
As far as i know the water pump on the truck is factory. And yes the temp goes back down when i'm going down the road. How much restince is supposed to in the fan cause it don't have much when i compare it to aonther vehcile
Old Aug 25, 2012 | 12:08 PM
Truckin Bob
High idle indicates a vacuum leak.
A vacuum leak will cause a lean fuel mixture.
A lean fuel mixture will make an engine run hot(ter).
Follow the path !!!!
Bob
Old Aug 25, 2012 | 12:13 PM
ford303's Avatar
ford303
It dont idle fast all the time, Just when the temp gage starts to move over to the hot side
Old Aug 25, 2012 | 03:11 PM
yorska's Avatar
yorska
If the temp goes back down when moving then the fan clutch is the most likely problem. How much resistance it is supposed to have is difficult for me to put in to words, but you said it has less when compared to other ones you tried so which again sounds like its shot. Last check that I can think of is look at the front of the clutch for oily/waxy residue. dry dirt is to be expected but if it looks wet thats not a good sign.
Old Aug 27, 2012 | 08:01 AM
rustywheel68
i'm not as familiar with these newer trucks as i am with the old stuff...but with you having more than 230,000 miles...everything is likely worn out. i'd swap the fan clutch and the water pump.
Old Aug 27, 2012 | 12:28 PM
Truckin Bob
Check for error codes first.
A sticking (not stuck) EGR valve will cause a vacuum leak......high idle........lean condition..........running hot(ter).
A sticking (not stuck) IAC will cause a vacuum leak......high idle........lean condition..........running hot(ter).
Bob
Old Aug 27, 2012 | 02:19 PM
willowbilly3
I don't think a vacuum leak would cause a lean condition. All the IAC is, is a controlled vacuum leak. The ECM will add the fuel to keep the mixture correct if everything else is functioning properly.
Old Aug 27, 2012 | 11:41 PM
ford303's Avatar
ford303
The engine hasn't came on since its been doing this. But i'll have it check anyway. I'm going to try the fan first or get a electric fan, and see what that does when the funds allow me too. I've hadn't any problems out of the egr that i know of since i've own the truck. But like i said it only starts to idle fast when the temp gage goes up.
shotgun
Oct 17, 2008 11:58 PM
Ed the outdoorman
Oct 4, 2005 12:57 PM
Twohands
Electrical Systems/Wiring
May 22, 2005 07:58 PM
ricky1978
1978 - 1996 Big Bronco
Sep 1, 2004 01:04 PM
Jack01
Jul 27, 2004 07:15 AM
