That is one of the limitations of the DB2 pump, there is no boost reference built in, all the pump knows is your foot is asking for more fuel, not how much air is being pumped through the engine.
My cummins with the AFC, not only can I control max fuel, but I can also control how much of that fuel is available at no boost, as well as up to around 15 psi or so.
Still, a dyno is pretty much worst case scenario for smoke.
X2... An aneroid is a great idea for these things, thats why i made the thread the other day... I just wanna mess around with the hypermax one until mine comes to fruition...
Out on the street though, its not bad at all... I only have to move the throttle a 1/4" or so to cruise... The smoke is there for somebody that deserves it though...........
I tried tracking it down on the sheet to find a peak torque, and my truck kept pretty close with 2.1:1 TQ to HP ratio as before....
with the 345rwhp value, I'm looking @ about 730rwtq
At 2600rpm, the ratio is 2 TQ to 1 HP because of the mathematical relationship between them. That ratio changes. At 3300 rpm the ratio is 1.59 TQ to HP.
So, it depends on the rpm. You can't just double the max hp and get torque. If you happened to know what your horsepower at 2600 rpm was, then yes, you could double it.
So I am not sure if they gave me the correct sheet for my truck. The sheet shows my max power at 332.1... I really don't think this is mine!!!! I could have sworn the screen was showing 125 max power when they were dynoing mine. Should I give them a call and see if they kept track of whose dyno run was whose?
Your max torque is probably around 600.
Its more with these engines.
The Peak Torque to Peak HP ratio is 2:1... This is something confirmed by not only our past dyno's, but just about every IDI ever dyno'd. My numbers extrapolated per my last dyno run, in which my setup hasnt changed aside from the intake manifold, which probably gained me minimal, but didnt change the curve, gives me 694wtq @ 2200 RPM... Thats close enough to 2:1 to confirm that...
Duane
Duane,
I think your numbers were flawed from the beginning anyway, Obviously the 340 number isnt right, and I think the 125 number is severely low for the factory turbo, especially since your timing was right on for your setup... You should have seen about 175 at the very least.
I dont think calling them will do much, I was watching the screen when you ran, and the numbers were up there as well... I think it has to do with the guy operating the dyno...
Ok, my max torque is 15ft-lbs less this time, than last time I dynoed 290hp.....
You don't understand. I am not talking about a specific rpm. An engine configuration will hold close to a certain max tq to max hp ratio.
I just plotted out the rpm and hp numbers from my dyno sheet to hunt for peak torque....
@ 2600rpm I have peak HP of 345, that makes torque 697 @ 2600
My peak torque is actually higher than I thought. On one pull peak torque would of occured @ 2250rpm, where I was making 325rwhp. This equates to 758.62rwtq.
Duane... if you call and ask for margo, tell her who you are, and she can get you your sheet. They save all of the runs.
What happened was that 6.0 that ran before you, was not deleted from the screen before you ran, so they gave it to you, thinking it was your highest run.
Here is a great video Pat put together of my runs. @ 1:46 you can see all of my dyno pulls. The one weird looking curve that's shifted way to the left was me using the vehicles brakes to load the truck and try to spool my charger, I let out very early, as you can see, but it showed me what I have capable for a peak torque.
After I got home I looked at the sheet and was kind of blown away, then reality set in and I specifically remember looking at the screen and it said 125. Anyways, some changes are going to have to occur after I return from deployment, I had a hard time swallowing 1/2 tons passing me with close to the same load going east for vacation.
