Modular V10 (6.8l)
Torque Shift Fluid Change
Old Aug 18, 2012 | 11:03 AM
super 6.8's Avatar
super 6.8
I know this should be in the Super Duty forum but......
I need to change the fluid in my 07 V10 auto. I have read that the machine needs to heat the fluid in order the do a full flush. I called the 2 area dealers today and neither has the heated machine but both guaranteed they could do a full fluid exchange. What gives?
The part that scared my was one dealer, the biggest, didn't even know there was an external filter.
I have never pulled real heavy with this truck. My boat is only 4k lbs and is the heaviest I have pulled. Should I just drain the pan and replace the external filter?
Also, both dealers still used Mercon SP. I thought that was phased out?
I searched thru most of Mark K's posts and couldn't find a clear answer.
Old Aug 18, 2012 | 11:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That must have taken quite a while to search through my 7,000+ posts!
Without a heated flush machine they can't do a full fluid exchange. If they don't know it has an external filter they won't know they can't do a full exchange.
If you can't find a heated machine your only option is to drain and refill the pan. I thought MERCON SP was going away, too, but it still seems to be available. You can use either MERCON SP or MERCON LV. Either one is fine.
Old Aug 18, 2012 | 08:52 PM
super 6.8's Avatar
super 6.8
Thanks Mark. I did look thru quite a few posts.
I will pick up 8 qts and the toilet paper roll and get to it.
dave boley
Sep 25, 2011 06:17 PM
DIXIEDOG1
Aug 4, 2010 07:24 PM
beerformeplz
May 21, 2007 08:36 AM
miichael
Mar 24, 2006 01:21 PM
zbs60
Feb 10, 2003 05:02 PM
