This is prolly a 1 page thread at most
The 450 has:
Universal Joint at the front hub (2)
Upper ball joint (2)
Lower ball joint (2)
Tie-rod at pitman (1)
Tie rod at connecting rod (1)
That's all I can remember seeing/greasing. I'm sure I'm missing some and it will cost me money later . The joints take a fair amount of grease though. Tough to say exactly how much with the DeWalt cordless grease gun, but it seems like it's about a half a tube.
The following 4 users liked this post by SavageNFS:
Received 7,107 Likes
on
[Rant]
Why does the grease tube in my grease gun (same as Andre's) piddle oil all over the inside of the case while in storage? I've had the same problem with manual grease guns. I've been using Valvoline grease that adheres to the Ford spec for lubing the front axle. My garage doesn't get hot in the summer. It's to the point where I'll find every fitting to grease in every vehicle and then throw away the rest of the tube of grease so it can't leave a mess.
[/Rant]
I've heard that the Lucas Red-n-Tacky doesn't do that, but I haven't tried it yet. I have a case of the Valvoline I'm working through.
[/Rant]
The following 4 users liked this post by HRTKD:
[Rant]
[/Rant]
[/Rant]
on
The following 3 users liked this post by HRTKD:
The following 2 users liked this post by SavageNFS:
Received 4,180 Likes
on
The following 6 users liked this post by Sailor Roy:
Received 4,334 Likes
on
Howdy all. Just getting the Warden home from Dental Surgery here at Alpha. She has round 3 next Wednesday.
Need to get the lawn mowed now. Later this afternoon, I have to go to town and see about a bid for our Security System / Camera's at the Sportsman's Association. We've re-run/replaced a damaged cable. Need to get it hooked back into the system. We've lost faith in the original installation company and are looking for a new vendor. Then, I have to give a report to the Board of Directors at a meeting tonight. Maybe I'll get really lucky and they'll fire me!!!! Not going to happen, but one can hope.
I use the Alien Tape. We used the Command Strips but could never get them to hold. Seemed to work for a couple of weeks then we would find hats and windbreakers on the floor. Do you guys prep the wall any?
Off an running.
Off an running.
The following 4 users liked this post by Seabiscuit-P3:
on
I looked up the Alien Tape. It seems very different from traditional tape. It's touted as "reusable" but they don't say much about "removable". I would be quite reluctant to try to pull it straight off of a wall that has RV wallpaper.
I've used my heat gun to smooth and refasten the RV wallpaper. I used my finger to press it down but probably should have used a plastic putty knife or a rubber roller.
Received 3,946 Likes
on
The following 4 users liked this post by helifixer:
on
Received 5,363 Likes
on
The following 10 users liked this post by Jigger2020:
on
The following 6 users liked this post by HRTKD:
on
The following 4 users liked this post by Desert Don:
