Fog Lights
Old Aug 17, 2012 | 01:13 PM
Jimbo1977's Avatar
Jimbo1977
Fog Lights
I was looking at adding some PIAA or KC lights to my 99 F350 CC Dually 7.3. I was checking to see if there is any other good brands. Also where is a good place for price. The other issue is with PIAA and KC says I can only put 2 lights per relay setup, but I'm trying to put 4 lights on the relay. So I would have all 4 lights come on with 1 switch wiring setup. Any information would be great. Thanks
Old Aug 17, 2012 | 01:31 PM
GonzoCSU's Avatar
GonzoCSU
you can wire 2 relays to 1 switch, or look around and find a relay rated for a higher load.
Old Aug 17, 2012 | 02:01 PM
crop harvester's Avatar
crop harvester
your relay is probaly rated in amps and your lights are in watts divide volts [12 ] into your watts that will give you amp draw from lights, then check your relay amp rating.
Old Aug 17, 2012 | 03:42 PM
Jimbo1977's Avatar
Jimbo1977
Thanks for the info. I'll look more into the amps rating.
Old Aug 17, 2012 | 04:58 PM
PwerStroke99's Avatar
PwerStroke99
powerstroker02
Apr 16, 2011 07:52 AM
musclecars90
Electrical Systems/Wiring
May 27, 2009 02:16 PM
schmidt64
Dec 7, 2007 07:32 PM
rocco913
Nov 8, 2006 07:28 PM
islandman63
Oct 14, 2006 08:41 PM
