Radio Question
Old Aug 23, 2012 | 02:42 PM
AZ_Ford_Guy's Avatar
AZ_Ford_Guy
Thanks for the info guys.
Flareside- I appreciate the offer, but I am gonna pass!(you even asked for the top of the line model! What? base unit not good enough for ya?!?!?)
Explorer- I will keep the sizes in mind. My only criteria is that it must have an aux input, so factory units are out unless I want to solder one in, but then you still have a very low power radio with limited functionality.
Old Aug 23, 2012 | 03:11 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Modern Factory replica units should have those inputs... If you can find one that matches... check radios for the 70's 80's mustangs etc...
There are also services that gut the factory radios and put modern electrics inside...
So those could be options as well...
Old Sep 5, 2012 | 08:14 PM
AZ_Ford_Guy
Radio Update
So, after much debate, I had decided on the unit from custom auto sound. Given their equal sound specs, I was content with the CAS unit because frankly it looks factory. Then, while doing more research on where to get it, I came across a TON of negative reviews on the CAS unit. Many people are unhappy with the sound quality, the "cheap feel", and the durability of the unit. Seriously, 9 out of every 10 reviews I found were against the custom auto sound unit and almost all of them had supporting evidence for their claims. IT WAS ESPECIALLY DISCONCERTING TO SEE THE REP FROM THEIR COMPANY CHIME IN ON ALL THE FORUMS TO DEFEND THEIR UNIT WITH THE EXACT SAME RESPONSE! Now I know that we are all more inclined to post things like that when we have a negative opinion, and if they were somewhat more balanced I wouldn't have been so concerned.
In the end, I decided on the retrosound model. It will be here in a few days, and I will post pictures once installed. Thanks for your opinions all!
kmcdonough
Mar 29, 2009 04:18 PM
HD74
Mar 19, 2009 11:16 AM
jle70
Aug 24, 2008 07:30 PM
kailor
18
Nov 10, 2007 11:10 PM
PRyan1983
Feb 19, 2003 11:37 AM
