1997 powerstroke problems
Old Aug 15, 2012 | 09:59 PM
wilzy14's Avatar
wilzy14
It does have crusie and it does cut out with it on.
Old Aug 16, 2012 | 12:55 PM
jyount's Avatar
jyount
The OBS F350s didn't have a convertor. The older SDs 250 or 350 didn't either. Is it throwing any codes? Sounds like maybe the HPOP isn't making pressure if it is doing it worse under power. The map sensor may not be seing boost either. That can be the sensor or turbo boost or drive pressure leaks. Usually though turbo problems just seriously hampers power, not cuts out. Sure the UVC harnesses are ok? You can slip a feeler gauge under the armature of each injector next time you are under the covers. If they are worn out they will have very little clearance between the armature and the body. Any way you can get a sound bite of it cutting out?
Old Aug 16, 2012 | 01:23 PM
wilzy14's Avatar
wilzy14
I changed the CPS and now it run like a raped ape!! It had a grey one with a gold looking plate and it had 3 holes in the end of it and the new one had no holes in it and silver plate.Thank You Guys for all the help
Old Aug 16, 2012 | 01:40 PM
CampSpringsJohn's Avatar
CampSpringsJohn
I've never seen one with holes in it. Glad it's fixed! Hope to see you around the forums. What part of the country do you call home?
Old Aug 16, 2012 | 06:15 PM
wilzy14's Avatar
wilzy14
Washington In Thanks for your ideas on this truck. Now I have a ford towing my chevy drag truck to the drag strips.
Old Aug 16, 2012 | 06:22 PM
CampSpringsJohn
I know where you're at! I get out there on occasion.
landmobile
Mar 16, 2012 10:20 PM
joey101
Jan 19, 2011 08:45 AM
fyrbrd
46
Oct 25, 2009 11:54 AM
SNIPER168308
Mar 15, 2007 03:58 PM
deano70
1997 - 2003 F150
Jun 12, 2006 05:30 PM
