Fuel inertia switch problems.
Old Aug 15, 2012 | 08:10 AM
LMPLLC's Avatar
LMPLLC
Has anyone had a fuel inertia switch cut power intermittently? I hit a deer on the driver side of my excursion and it caused enough damage to have to replace the radiator support and get a new clutch fan. I was driving on the highway last night to just have my truck die on me. I recently just replaced the fuel pump in my truck. There's a thread floating around here somewhere about it. Anyways, long story short, there was no fuses blown and the relay was working. But I wasn't getting any power to the pump. So I pushed on the fuel inertia switch and it didn't click and nothing happened. So I checked with a test light to see if power was going to it. It was getting power. So I jumped the wires and got power to the pump. Started the truck up and drive it home and drove it for about 5 minutes and nothing happened again. Anyone ever hear of an inertia switch going bad? That's the only thing I can think is wrong now. I've been through the whole fuel system! I know it like the back of my hand now. Lol
Old Aug 15, 2012 | 08:13 AM
LMPLLC's Avatar
LMPLLC
Oh and since I can't edit my last post because I'm on my phone I hit the deer last year around this time.
Old Aug 15, 2012 | 09:10 AM
srteach's Avatar
srteach
If the power shorted when you hit the deer, the switch could have arced. That could cause problems with the contacts.
While the switch does not usually fail, it is possible. Test the switch with a continuity tester or DVM to see if it passes voltage or resistance.
Old Aug 15, 2012 | 09:22 AM
LMPLLC's Avatar
LMPLLC
Do you know what voltage I should be looking for or ohms?
Old Aug 15, 2012 | 09:53 AM
srteach's Avatar
srteach
Any voltage in should equal voltage out through the switch contacts, as close to 0 ohms as possible.
The inside circuit is just straight through switch, no resistors or other components other than a switch contact. It should ohm out as if it is a wire when closed. If the circuit doesn't close, or you have high resistance, there is a problem. High resistance could be burned contacts, possibly due to arcing.
The insides of the switch include a weight (usually a loose ball) in an inverted cone (or a pendulum setup) that trips a cutoff switch on impact. That is why the switch requires a certain orientation for the mount.
Old Feb 2, 2016 | 04:15 PM
zarmo's Avatar
zarmo
Where is your Inertia valve?
I hit a large pot hole and my truck also dies in its tracks, I have also checked all the fuses and associated causes. my owners manual says the inertia valve is in the right side kick panel, I pulled the panel and found nothing there. I looked under the hood all around and found nothing that resembles this valve. so where was is it on 97 F250 7.3L that is dead in the driveway
Old Feb 3, 2016 | 07:34 AM
tjc transport's Avatar
tjc transport
i ain't rite
your 97 does not have an inertia switch, that is a 99 and newer thing on trucks with electric fuel pumps.
your 97 still has the mechanical fuel pump on the engine.
also, your in the wrong forum, you want the 94.5 to 97 powerstroke forum, one down from this one in the diesel section.
Old Feb 3, 2016 | 09:44 AM
zarmo's Avatar
zarmo
Thank you for answering that. I am now on a new thread with this issue on the 94.5-97 7.3L forum.
again thanks so very much.
Old Dec 13, 2022 | 07:33 AM
K2Montana's Avatar
K2Montana
2nd Gear
Inertia Switch Pre-94.5
Originally Posted by tjc transport;[url=tel:16009213
16009213[/url]]your 97 does not have an inertia switch, that is a 99 and newer thing on trucks with electric fuel pumps.
Actually, the info on Inertia Switches being '99 and newer is incorrect. My '88 F250 XLT Lariat has and Inertia Switch, as does my '90.
Old Dec 13, 2022 | 07:50 AM
Kwikkordead's Avatar
Kwikkordead
Those are gasoline powered with electric fuel pumps, correct?
Only time inertia switches are needed. Mechanical fuel pumps stop when the engine stops.
Old Dec 13, 2022 | 07:59 AM
tjc transport
i ain't rite
how can a mechanical fuel pump run off an inertia switch?
Old Dec 13, 2022 | 09:53 AM
K2Montana's Avatar
K2Montana
2nd Gear
Inertia Switches 2.0
I have 1 of each, in regards to gasoline and diesel. Electric fuel pumps, as they became more the norm, brought Inertia Switches as a safety measure.
joejoebo
1983 - 2012 Ranger & B-Series
Oct 21, 2012 07:12 PM
Dutter
31
Sep 27, 2011 10:45 PM
jablonowski05
Sep 4, 2008 03:08 AM
kormelistdijetta
Jun 23, 2006 05:39 PM
emboyd
Aug 27, 2003 08:53 AM
