headers
Old Aug 14, 2012 | 06:42 PM
Schickel's Avatar
Schickel
headers
Is it possible to get both headers on without romoving to engine or other major components in the engine compartment on a 77 f250 with a 400m
Old Aug 14, 2012 | 08:04 PM
LI250's Avatar
LI250
It looks like there is enough room. With AC or without? AC makes it tight. The driver side would be the tight side without ac. You my be able to drop it out the bottom. Then again I have a 4 inch lift and 35's so there is a bit of room below it.
Old Aug 14, 2012 | 08:08 PM
Schickel's Avatar
Schickel
Well i had to drop the front drive shaft and disconnect the clutch linkage but i got em on and boy does it sound great!
Old Aug 14, 2012 | 08:21 PM
OldStyle's Avatar
OldStyle
Rusty Roller
A little less than 1hr & 1/2 isn't bad time wise! Congrats
Old Aug 14, 2012 | 08:51 PM
Schickel's Avatar
Schickel
Thank you much! And i cant take all the credit PB blaster did most of the work on the manifold bolts
Old Aug 14, 2012 | 10:12 PM
vic_v8's Avatar
vic_v8
which headers did you go with?
William819
Jun 21, 2016 04:27 PM
Wmrdalydvm
Aug 30, 2013 08:17 PM
makohon
Mar 19, 2008 05:19 AM
