Starter Problem - slowly going south
Old Aug 14, 2012 | 04:58 PM
gudone's Avatar
gudone
Hi,
I have a 74 F-250 that now has 300 6 (used to be V8). Not sure the exact age of engine but same era.
When starting, the starter turns but does not always engage the engine, just spins. At first this problem only happened intermittently but now seems to be getting worse and worse to the point sometimes can't start it.
The truck has a new battery and a new solenoid.
I am assuming this is the starter itself slowly going away ... but not sure, what do you guys think?
I am also assuming that if a get a new(rebuilt) starter it should be for the 300 engine, correct?
Any advice greatly appreciated.
Cheers
Old Aug 14, 2012 | 08:39 PM
fmc400's Avatar
fmc400
MSEE
Sounds like a dying starter to me. When you buy the new starter, you'll want to order it based off the drivetrain as you suspect.
Old Aug 15, 2012 | 10:00 AM
gudone's Avatar
gudone
Thank you for replying. Cheers
heavy_d
16
Mar 21, 2014 12:21 AM
nutinbutford
Sep 12, 2008 01:38 PM
inline6 Red Neck
Oct 12, 2006 04:56 AM
CINCYTREE
May 2, 2004 11:19 AM
cwgoff
1997 - 2003 F150
13
Apr 28, 2004 09:30 PM
