Sponsored by: Real Truck
Clunking sound?
Old Aug 17, 2012 | 10:38 PM
catscratch's Avatar
catscratch
Checked with it jacked up and on the ground...
Old Sep 6, 2012 | 12:02 PM
maple sapper's Avatar
maple sapper
to check sway bar links I use a long solid bar or steel or pipe. Slide it under truck far enough to leverage it or use block of wood on ground to raise bar a bit. Then lift. You will see the slop and clunking noise at that point.
Old Sep 6, 2012 | 12:54 PM
catscratch's Avatar
catscratch
What are you lifting on; the center of the sway bar, the ends of the sway bar where the links attach, the frame of the truck, or on the front differential?
Old Sep 6, 2012 | 01:00 PM
maple sapper
right under the link joint is where the bar makes contact with the sway bar. The leverage bar goes to ground or piece of wood depending on lever bar length. The bar I use is 5' long or so. So standing by side of truck, you just lift bar and see the play.
Old Sep 6, 2012 | 02:05 PM
catscratch's Avatar
catscratch
Ok, Thanks.
Old Sep 6, 2012 | 03:57 PM
jsalty's Avatar
jsalty
After reading this thread, I checked my sway bar bushings (not the links but the bar to frame), they are shot. I went to the local autopart stores and none of them had busings for the 3/4" or 7/8" bar that I have, all the descriptions at the part stores showed 1 1/4 or 1 1/8" bars. Does anyone know where I can grap a set?
2005 F350 4x4 Crew Cab King Ranch 6.0L
thank you
Old Sep 7, 2012 | 07:14 AM
Rick03F250's Avatar
Rick03F250
jsalty, are you sure of the size? Try here, this is where I get mine.
Truck Parts and Truck Accessories
Old Sep 7, 2012 | 07:31 AM
FineSeventyNine's Avatar
FineSeventyNine
Tennessee Hillbilly
Check the track bar bushings too...that's what was causing the clunking in mine.
Old Sep 7, 2012 | 08:09 AM
jsalty's Avatar
jsalty
I am sure of the size, placed a mic on it, 21.5mm (7/8"). No idea where it came from but it has been on there since before I got the truck. Will recheck local auto part stores for bushings.
Thanks
Powerstoke73
Aug 18, 2014 05:23 AM
Jager
17
Jan 10, 2011 01:10 PM
jim6liter
Jun 11, 2009 07:53 AM
raptor131
Sep 29, 2007 12:17 AM
Big
Jan 25, 2006 07:26 PM
